TurboTony said:Yep, did it on mine. My engine guy does it on all his chevy builds.
He removed the stock bypass spring/valve dealy and tapped the hole for a pipe plug. It works just fine. Just don't rev the hell outta your motor when the oil is cold and thick.
HTH
Tony
myclone said:Ditto... or can shim the spring in the bypass to let less oil bypass the filter but still have a relief if the filter gets clogged, forget and go high RPM with the eng cool, etc.
Tony,TurboTony said:Yep, did it on mine. My engine guy does it on all his chevy builds.
HTH
Tony
