Overboost code 31
Sy 0145
Anyone else experiencing overboost at wot with turbotweek sy 3 bar velocity chip? Target boost max of chip should be close to 25 psi. I got overboost around 28 psi. Would this be normal because of the 25 psi max of the chip?
neildemo
Administrator
I found that when you run these trucks in colder temps the boost will be higher, most likely due to the denser air. Set the target lower for colder temps.
