what can be done to a motor to improve the oil system?
are there certain oil passages in the block that need modification?
are there different restrictors or bypass valves that improve flow?
what is the best oil pump to use and what volume and what pressure springs?
also, is the stock oil cooler sufficient? what's the best way to add a additional cooler?
is the oil system in the syty's the same as regular 4.3's?
i'm just full of questions.
