No 3rd or 4th
Big Mike
I was driving down I 95 55mph and truck stuttered puff of smoke hit the rev limiter on digital 6 set to 4100rpm (new motor) and lost 3rd and i think 4th.I think Data Master recorded it if you need to see it. The trans still has 1st 2nd and Reverse. I checked the fluid and was low so I filled it but I think it may be to late. Any ideas??
Thanks
Mike
George Blake
DONATING MEMBER
Re: No 3rd or 4th
Burnt 3-4 clutches. Common problem. You'll need a rebuild with the current updates. I can get you a DIY kit similar to the one I've almost got finished for Bruce if you need it. It is basically a TRUE diy that you'll be able to install as long as you have some basic tools a, torque wrench and a dial indicator.
syclonekid43
Re: No 3rd or 4th
how much to rebuild a tranny with a fe wupgrades? i blew mine up a few weeks ago. i only have reverse. post it here if big mike dont mind or you can PM me. thanks
George Blake
DONATING MEMBER
Re: No 3rd or 4th
I only build one kind of transmission for syty setups.
$1850.00 for trans plus shipping. This is with a buildable core.
