Need some help with reading data in Tuner Pro RT 4
Rexxenexx
I installed TP4 to see the difference from TP5. The graph is so different from 5. Scrolling seems to just go forward constantly? Also, the Boost in PSI doesn't account for atmosphere.
I'm using the 58.ads and 58SyTy.xdf straight from their site. Is there anything I can do to make the graph work like TP5? Or display and scroll through more logically?
Attached is the log file. At the end is this last run. You can see it, but like I said, it's hard to just go exactly to it if you can't see the whole graph like TP5. I appreciate any tips. TIA
  • New1.zip
Rexxenexx
NM. I uninstalled it. If I want a seismograph I would have joined the USGS. Datamaster seems to be the best daily data logger until you need Wideband info or if you’re lucky enough to have Moates stuff, the TunerProRT5. Even then, on my old laptop TP5 lags when I try to scale even a short 5min log. DM is like working-with-text fast, I wish it read the Wideband then I would uninstall TP5 too until I get a TurboTweak chip.
