Need fast help checking timing!!!
JoeLutz
On 2001-11-25 10:15, Daron wrote:
On 2001-11-24 23:36, joeelutz wrote:
When I disconnected the tan wire, my Ty also tried to die. After a while, though it smoothed out.
I never disconnect the tan wire while the vehicle is running. I turn the vehicle off, connect timing light, disconnect tan wire, then start the truck, check timing. Once timing is checked, re-connect wire, remove power to ecm for 30 sec or so to clear code, remove timing light etc....
Yea that would probably be the smarter thing to do. :smile:
Typhoonracer
Old Guard GURU
Guys,
The stock balancers are very prone to "slipping" ANYTIME you do a timing check ALLWAYS do a TDC test first!!!!!
If you are off even just a little bit then your timing reading is not worth spit....
