SyTyJedi
Jedi Council
Print this out and put it somewhere, these are the rules of PCV...there is a question at the bottom.
-DO NOT put a PCV valve on the drivers side vavle cover
-DO NOT put a breather on the oil filler cap
-DO put a breather in the grommet at the rear of the vavle cover if you wish (cleaner and almost necessary with aftermarket intake, unless you want to run a line to other side of the motor)
-DO NOT put breathers on either one of the PCV valves on the passenger side valve cover, they WILL NOT function properly.
-DO NOT route the PCV lines into a catch can with a breather on top
-DO route the PCV lines into a CLOSED catch can ONLY IF it has an outlet hose and route that to the proper location
-DO put clamps around the PCV valves in the "T" connector that they sit in to keep them from popping out.
These are the rules. If you do not follow the rules, expect oil leaks, oil residue everywhere and more hassle than if you left it alone.
If you want to put a catch can (like GReddy) on one of the PCV valves, put it inline with the one going to the throttle body, the most oil vapor goes thru there since you engine is always in vaccuum. I had hardly any oil coming thru the line going to the turbo inlet to vent under boost. Most of the residue would stay at the beginning of the line and never make it to the turbo anyway.
Question: Why do I see pictures of built motors with NO pcv valves or the PCV system routed incorrectly? I've seen this on a number of built motor trucks now...why are people ignoring this?
Just FYI...
Tyler
Just FYI...
Tyler
