JAY
Has anyone had any luck with these transmissions?
http://www.monstertransmission.com/700R4_c_3942.html
I run one of their SS Supeduty 700R4's. They built it to hold 650HP/600ft lbs of torque. It shifts way harder than the stock transmission. I also had them install a TCI constant pressure valvebody to keep from burning the trans up due to an improperly adjusted TV cable. They start around $1450, but when I was done adding options it was just under $2000 with free shipping. So far I am happy with it, and their customer service. On a side note I did go with the fluid they recommended (Schaeffer's Supreme) just incase this thing crapped out I didn't want that to be an excuse.
so did you make it out to the track on wed. I ended up taking mine last wed.I've only recently got everything back together, but I received & installed the trans back in March. I put about 60 miles on it so far. This Wednesday I'm going to the track to begin tuning (finally got everything installed that track tech requires). With all things considered I should run mid-high 11's if all goes well. Not sure on power, maybe 425-500?
Yeah, made it to San Antonio Raceway and got six runs in. So far the best was 13:64 @ 95 MPH. That was running only 7.5psi with no meth and only 14 degrees advance. I ordered a spring kit for my wastegate. The RPM one I have only has a 6lb spring so that will limit me to 12psi max with the boost controller. Realizing this I called it a night, and will return with either a 10 or 15lb spring.so did you make it out to the track on wed. I ended up taking mine last wed.
