Re: launch with a 4l80e
Falco said:
Thanks George! I'll try to shift it then. I'm a bit afraid though, to push it forward into neutral accidentally...
Don't you have an aftermarket shifter? I thought it had a Neutral lockout on it.
For everyone looking at this, this is VERY important.
If you shift ANY transmission into neutral during ANY forward driving, your forward drum, (input drum on a 700r4) will spin at 2.5 to 3 times engine rpm. So if your speeding down the track at 6500 rpm, your forward drum will suddenly spin at almost 20K rpm. This WILL result in catastrophic failure as the forward assembly was never meant to spin at this rpm and centrifugal force will grenade the assembly resulting in transmission damage, vehicle damage, driver injury or death. I'm not exaggerating this point and Zsolt has the right to be concerned.
I thought you had a lockout, though. If not, you can launch it in OD.
