canadian
sy in progress
Thanks to Josh for hosting the pics. Geoshitties sucks.
It is true that the KB downpipe won't work with the stock headers and turbo the way it comes, but with a little cutting a rewelding, it'll work just fine. I bought a used KB downpipe from someboey (can't remember who) in the classified section and figured that there's gotta be a way to make it work.
First thing is that the KB downpipe comes in two sections. The upper section bolts to the turbo and the lower section slips into the cat. The joint between the two is flared so the upper portion can slip into the lower portion and away you go.
Since the KB header/turbo combo locates the turbo up and away from the motor, just bolting the DP on isn't going to happen. You can see the mismatch here:
You can see how the lower half of the downpipe comes up between the motor and the frame rail just like the stocker. Since this is the same, the portion that will need to be modified is the upper half of the downpipe.
The upper half of the downpipe is cut right behind where the 02 sensor mounts, and the portion that bolts to turbo needs to be rotated so that the bolt holes line up. The only problem with this is that it puts the 02 sensor farther away from the motor. You can either drill a hole and weld in a new 02 sensor bung, or make the 02 sensor wires longer.
You can see where the upper portion was cut and rewelded in the following picture. It's the weld right after the 02 sensor bung:
I had to trim and inch or two off of the upper half to make sure it lined up with the back of the turbo and the lower half of the downpipe. With all that said and done it wasn't that big of a deal, and now I have a downpipe with no nasty crimp bends like the stocker. Here's the comparison:
And all mounted and ready to go. Need to work on the O2 sensor wiring now. I painted it with high temp header paint. Guess I'll see how long that lasts:
