There is talk of guys using a place that cleans, balances, and gives you before and after flow rates of each injector for $10 each. Anyone know of this place? Or is it worth getting 50's.
I always flow test the injectors before and after cleaning. Yours were actually in very good condition before they were cleaned. There was only a slight improvement in the static flow readings. Before cleaning #3 and #6 were down by .5% from the others. This is a sign of a fuel system that has been well maintained and is good working order. You may not see any improvements in fuel economy or performance but you have the knowledge that there are no problems with the injectors at this point in time and they should serve you well for another 10 years.
have finished your injectors and they are a very nice set. They are all flowing within 1% during the dynamic flow test and they are all exact during the static test.
Here is the Static flow test comparison data:
Injector #1-100ml
Injector #2-100ml
Injector #3-100ml
injector #4-100ml
Injector #5-100ml
Injector #6-100ml
Here is the Dynamic flow test comparison data:
Injector #1-99ml
Injector #2-100ml
Injector #3-100ml
Injector #4-99.5ml
Injector #5-99.5ml
Injector #6-99ml
Your total for servicing the injectors and the return shipping via UPS regular ground comes to $68.49.
They were very service friendly, i would recommend this place to all of you that need your injectors cleaned, and for a $5 extra he match your injectors if you have one that are so bad it can't be fixed.
