I had to go look up the replacement proceedure for the iac and the first paragraph says not to push or pull the pintle, because the threads on the worm gear can be dammaged. It says if the measurement does exceed 1.125 " (28mm), the unit should be replaced along with the O-ring seal (Make sure the new one has one). After replacement, turn ignition on for 5 seconds, then turn it off for 10 seconds, then start the engine and check for proper idle. Of course this is gm's proceedure for their type of IAC valve, there should be an instruction sheet enclosed with the aftermarket type. As cheap as these things are now, I wouldn't risk having one come apart inside... the pintle won't go anywhere, but I have seen the spring & wormgear imbedded in the top of a piston of a 86 tpi camaro... It was knocking a little...
