First, I can't get my idle iac count down below 100. I have done a full iac reset by turning key on for 30 seconds, unplugging iac, starting truck and let run until it is in closed loop then manually set idle stop screw to 650 rpm, turned of truck then reconnected iac. I can find no vac leaks or have an unsteady idle like a vac leak but idles at @ 900. I don't know where to look next.
Second, I have a random code 34 that I see in my data logs. I don't get a cel. I have a map voltage of 1.53 ( 3-bar) with key on engine off. I have followed the service manual troubleshooting guide for code 34 and there is no problem. Should I just ignore this until I get a cel hard fail?
Thanks,
Phil
Thanks,
Phil
