spooldup
Super Member
Ok here goes. The ty had to go in for more work. So the mechanic finds out that the tranny downshift cable has play in it and when you hit the gas it would hold back the throttle by about 25%. So he takes off the downshift cable and the throttle now opens fully. He says lets go for a ride. So we go and he is shifting it manually because the cable is disconnected. Anyway after like five minutes of riding we go back to the shop and thats it for the night. Now the next morning he finds a vac leak that we have been hunting for and fixes that. I am at work and not around to see whats going on at this time. So he says that he went for a ride and the ty boosted harder and he knew he had fixed the problem. Anyway the new problem he says is that my tranny is now BAD! What!!!! I can't beleive it! The Ty ran MINT the day before when we were both in it and all the others times i had it. The tranny was already replaced on 8/27/01. The fluid was bright red, no contaminents visible, no noise, no warning. He says that it goes in to first then second and then when it goes into third it's not there. He said it's as if it were in neutral. My ? is can this happen? It ran fine. Doe sit have anything to do with that cable?
