Help, no WOT 2-3 shift
joelkatdaddy
Hey guys, This questions isnt exactly related to sytys, but it is a 92 jimmy with a v8. You guys are the best so i figured this is my best stop. In my truck i have a 700r4 that was rebuilt about 3 years ago. It shifts great except when at WOT it will not shift into 3rd. If i let out to let it shift and floor it again it usually holds. Also, when the trans temp comes up when cruising in OD or 3rd, and i go WOT it will pull to second gear.Last thing is sometimes when i can get it to hold in 3rd gear without downshifting immediatly, when i get to about 4500 rpm or so sometimes it will try to pull down again. Any ideas? Thanx guys
Joel
joelkatdaddy
Re: Help, no WOT 2-3 shift
Ok well, i just tried to adjust the TV cable some. Ive been tighter with it before and it made it worse...So this time i loosened it 1 click at a time and drove. Well i finally got it to shift to 3rd, but all my shifts are now very soft and i dont get proper kickdowns. So i tried 1 click tighter and now i have my same problem back. Any other ideas? Thanx again
Joel
jwaller
Evil Genius/SyTy Guru
adjust the cable properly and go from there. if it still doesnt wannt shift you might have gov issues or worse, VB issues.
