I recently acquired this propshaft, and am trying to figure out if its a common one, or a locally made from a driveshaft shop.
The joint at the tcase looks about the same as stock. but the shaft itself at this joint isn't welded like the stocker...it just has a rib from the casting/creation.
This is the part i like, no boot, and a greasable joint. Also, the shaft can expand a lot further than a stocker....maybe this can be used for the 4l80e
