Re: Gm 4l80e
Matarex said:
auch 5k, thats a lot of Ca$h -.- but thanks for the tip -.- just had a lot of truble whit my stock trany and i whanted to pull some extra horses out of the engien
just don´t tthink the tranny can take the presure, and there isent a good tranny builder in EU
EU, as in European Union???
Well, that may change the evaluation of the core price....A trans is a fairly big heavy thing to ship across the pond, especially air-mail....
Read up on the plethora of posts on this board about the 80E....Depending upon what your desires are (hold 450 hp driven fairly conservatively or 800hp beaten on daily) will determine exactly what your build requirements are, and therefore the associated budget.
Cost wise, you're still not going to get away from a few things:
1.) Rebuilding the core
2.) Changing the output shaft for the custom 27spline shaft
3.) Computer to control the trans
4.) Adapter to mount up the Tcase to the 80E
5.) Torque Converter to suit your application (if one comes with the core, its likely to be all wrong for what you need, and the factory converters are beasts, like 65+ lbs).
6.) New transmission mount / crossmember.
Depending upon what labor you can provide and your desires, you may be able to do an 80E conversion for alot less than $5k. Research....
'JustDreamin'
