Rawpwr7 said:Mark the pinion nut orientation before you loosen it????? when my propshaft blew up it kept spinning while the transfer pinion was not do i still folow theese steps?? or what do i do?? I got my propshaft in and now need to install it...
SyTyArchives said:I'm having a feeling its not due to the shaft, rather the act of removing and re-installing the flange there.
SyGoat said:Welp I have some gaskets on the way. I'll try and do a comprehensive write up with photos.
mduffy said:On the stock propshaft, isn't that a viscous coupling? Since SyTys are all wheel drive so there has to be some mechanism accounting for slippage so that the T-case gears don't bind on dry pavement. This leads me to 2 questions:
1. If that is a viscous coupling on the stock shaft won't the Gilbert shaft bind up the t-case?
2. If that isn't a viscous (I have not idea if I spelled that correctly) coupling in the propshaft where and how do they slip?
