Fan temp turn on/off
sy605
I'm getting a chip burned to use the IC pump turn-on to control the electric fan on my truck now since I have an air to air intercooler.
I would like to know what everyone thinks a good fan on/off temp would be for 180* thermostat.
I was thinking 195 on/185 off.
Should this work ok?
I don't want the fans to run at cruising speed so thats why I think 195 on is better.
Any input?
mattw
Re: Fan temp turn on/off
So your chip burner should set the fan enable and fan disable MPH such that they won't kick on when you are on the highway.. but anyway I run a 195 degree stat and these are the settings I use to turn my fan on and off.. I'm pretty sure I found this info posted by Paul @ code59.org.. I put these settings in my bin and they have worked perfectly...
Fan Enable MPH Threshold (Lower) (KFANVSLK): 30 mph - Fans back on at 30mph
Fan Enable MPH Threshold (Higher) (KFANVSHK): 40 mph - Fans off at 40mph
I have a 195 T-stat
Fan Enable TEMP Threshold (Higher) (KFANCLTH): 85C
Fan Enable TEMP Threshold (Lower) (KFANCLTL): 80C
Hot Fan Enable TEMP Threshold (Higher) (KFANCTHH): 93C
Hot Fan Enable TEMP Threshold (Lower) (KFANCTHL): 87C
Cold Fan Enable Coolant TEMP Threshold (Low) (KFANCTCL): -40C (Disabled)
Cold Fan Enable Coolant TEMP Threshold (High) (KFANCTCH): -40C (Disabled)
Cold Fan Enable MAT TEMP Threshold (Low) (KFANMTCL):
Cold Fan Enable MAT TEMP Threshold (High) (KFANMTCH):
Fan Anticipated Motor Position Offset (KFANDS1): 15 Steps - How many IAC STEPS to add when the FANs kick on
Fan Anticipated Mode Decay Delta (KFANDS2): 1 Step - How much to reduce the IAC STEPS after the intial IAC addition of KFANDS1 when the fans kicked on.
1ST Time Decay Rate - Fan Anticipated Recovery (KFANCLC1): 0.4 sec
Decay Rate Fan Anticipated Recovery (NOT 1ST) (KFANCLC2): 0.4 sec
Fan On Delay After Conditions Met (KFANTIM1): 0.1 sec
MAP Threshold For Incrementing Fan Timer 1 BAR (KMAPINC): 60 kPa
MAP Threshold For Decrementing Fan Timer 1 BAR (KMAPDEC): 40 kPa
Max Time For Fan On After Ignition Off (KMAXTIME): 180 sec
Min Time For Fan On After Ignition Off (KMINTIME): 30 sec
Fan Off Delay If A/C On (KFANTIM2):
Flag
MAT Option for V5 Cooling Fan Logic (Cold) - OFF (not checked)
Table
Decrement Fan On Timer Adjust VS MAT (F83)
All values are 0.05 except 0C is 0.00
Increment Fan On Timer Adjust VS MAT (F84)
100C - 2.00
80C - 1.50
49.3C - 1.0
23.5C - 0.75
0C - 0.50
Mine are 165 on, 160 off with a 160 thermostat. My fan usually comes on and stay on because they don't have the cooling capacity in the warmer weather get the coolant temps down to 160. Only on cool days does my truck's fan cycle.
You do want to use iac step anticipation, my truck stalled at idle before I added some iac counts.
sy605
Sounds like the thermostat is closing on you. If your 160 t-stat "starts" opening at 160 then when the the fan cools all the way to 160 the t-stat is only cracked open. Try upping the turn-on to 175 and turn off 165.
I've been reading up since posting this and seems that too much fan cooling near the t-stat open temp will cause over-heating.
Who knows? I'm just reading it. I don't know this for fact.
It's not because of the thermostat closing. It goes above 165. It will be as high as 195 with A/C on. Most of he time it's in the 170-180 range unless it cool out. My mechanical fan use to always stay at 160 with 160 thermostat.
sy605
I have a 195 T-stat
Flag
Table
100C - 2.00
80C - 1.50
49.3C - 1.0
23.5C - 0.75
0C - 0.50
This is perfect. Thank you. I can stick with 195 since my truck is stock (for now).
Do your fans cycle a lot? Or normally? How about with A/C on during summer?
How about cruising speed?
What is the MAX temp you've seen?
Also, is this the IC relay on the ECM your using?
mattw
The fans did not seem to cycle a lot over the summer(what little bit I got to drive it).. In the winter they almost never come on.
They aren't allowed to come on at cruising speed. This part of the settings prevents that:
That forces them to go off at 40 MPH and not come back on until I drop below 30..
Maybe 200.. But I've got a great big Griffin dual core 31x19 radiator and two really health electric fans behind it.
I bought two big monster relays(1 for each fan).. There is no way the stock IC relay would last turning an electric fan on and off..
sy605
Yeah I have two weather pack 40 amp relays for my dual fan setup.
Thank you again for your help. :tup:
mattw
Did these settings work OK for you? They worked fine for me last summer and this summer the ECM won't command the fan on. If anyone has this stuff working and is willing to take a look at my settings I'd appreciate it.
You can download my .bin here:
http://mattw2.dyndns.org:81/tuning/Ramjet_50lb_PTE60_6-19-2013 back to old VE.bin
Data log here showing my temps way above the settings and no fan on commanded:
http://mattw2.dyndns.org:81/tuning/410 to home high temps no fan 6-19-13.xdl
Here is a screenshot of my settings:
And here is my dash with high temps and fans commanded off...
Any help would be greatly appreciated!!
mattw
Nevermind... My settings ARE working.. I have two electric fans.. One ECM controlled the other controlled by a thermal switch and a relay. The ECM one is working and there must be a problem with that custom 800x600 dash that I built not reporting that the fan is actually on...
