factory boost gauge wiring??
danimal95
I would like to wire in my factory boost gauge to work,every other gauge works perfectly with the LS conversion but I have no idea what I would need to do in order for that to work,any help is appreciated
RealFastV6
@jb_and_his_coffee
Re: factory boost gauge wiring??
About 12 inches up from where the factory ECU is, there's a 10 pin plug referred to as C101. This is probably where you cut in your tach wiring.
In that plug there's a green circuit that goes to the boost gauge. It's a 0-5v gauge.
What map sensor does the LS use? A 12v ref or 5v ref?
Sent from my iPhone using Tapatalk
