Dyno 2wd
R&C_RallySyTy
Little Big Man
Re: Dyno 2wd
Will 2wd (remove prop shaft) hurt tranfer case to dyno tune ?
That is a good question, but it seems like tons of SyTy guys do this. A AWD dyno is not always available. I'm sure someone who knows for sure will answer your question. I'm just about 90% sure you can just use a RWD dyno without any problems.
Ry368
one mile = 5280 feet
Re: Dyno 2wd
Yep....you can dyno it with just the two rear wheels with no problem after you remove the front prop shaft....I won't hurt a thing!:tup:
