milky 1704
026TB4U
who makes the loops for a 700r4 on a typhoon or are there any for sale
for the rear I bought a simple loop from summit. I think it was less than 15 dollars.
I welded it to a cross member that holds the exhaust up, and I think holds the leaf spring suspension together. looks like this
I dont know any rules about them, other than they have to exist. I figured this was the lightest strongest cheapest way. I'm not worried about the front yet, but I should be....I think if I did it Id do the same idea as what I did for the rear, but sideways and welded to the the drivers frame rail. bit of slop for removability.
i just thought about this, Ive seen your garage , good luck with the search.
I would be a little bit worried about having the driveshaft loop that far back, the reason for a loop is if the front joint breaks it will not allow the driveshaft to fall and pole vault the vehicle. That's why you never see them in the middle or rear of the vehicle. If the rear fails the shaft it just hits the ground and bends. You should buy another loop like you have and then weld them together to make an oval and space it off the trans crossmember or the torsion bar crossmember. I thought someone was making the Phil chivers loops so maybe do a search on the board. Good luck with the search![]()
