Typhoon-Dennis
which diff oil will i need for my Ty? where can i filled it in?
. To remove the old fluid, you have to pump it out or drill and tap the bottom of the case for a drain plug.
You are referring to the front differential in your post, as the correct way to service the rear diff is to remove the 10-bolt cover and clean everything out with about 2 cans of carb clean and some clean rags and compressed oil.
Go to harbor freight for a cheap effective pump, you'll pay about 10 bucks and they work great!
If you decide to install a drain plug in the front differential, be careful. You cannot just use a standard drill bit. If you do the drain plug will never tighten. The pipe thread is tapered and thus you must use a tapered drill bit.
Standard pipe tap is drilled with a regular DRILL BIT!!!
But if i were doing a drain plug i would never use a PIPE PLUG FOR IT !!!!!!!! And every blazer front diff i do i include a drain .
Doesn't work that way. There isn't a diff cover on the front. It must be pumped out.
Reread what he posted.
"...the correct way to service the rear diff..." and then explains removing the cover of the 10 bolt rear diff.
This type of drill powered pump???
http://www.harborfreight.com/heavy-duty-drill-powered-pump-98384.html
or a manual pump?
http://www.harborfreight.com/multi-use-transfer-pump-66418.html
Just wondering why the 35% was mentioned? The front diff rolls on the road 100% as much as the rear.[punctuation and syntax corrected]
What were you interested in in my answer???
Actually changing the DIFF oil is important. I always install a drain and it in fact does not leak. And if you feel you dont have to change the oil then dont. That glob of sludge was taken out of a diff with moderate mileage. I find it interesting that posting about modifications dont interest you marking. What would you like me to say? That i dont add a drain plug to the DIFF. Well i do and do it all the time. People like to drain fluids. I am a Detroit diesel certified shop and every big truck has drains on everything. If you feel you dont have to change the oil go for it. By the way drain plugs dont leak if installed correctly. Saying it is a leak point is WELL!!!!
MARKING their are a couple of ways to install a drain.
By the Way i make the drain PLUG. When rebuilding a diff it takes 30 SECONDS TO INSTALL It takes me app 1hour to install on customers trucks with the diff in place if they want one.
DaveP, we dont tell people where our shop is because with all of the highend cars we have in it (porsche,ferrari, bentley, Restomods) we wouldnt want a trashy bum like you to come peering through our windows. We dont need losers like you or other internet forum tough guys to tell us we do good work, the timeslips and trophies from many many many years of repeat customers are more then enough to keep us happy. id LOVE to see what you build
You have alot of spare time on your hands to stalk pictures out of me and my dad, im flattered , I guess all our LSX powered Gm cars must have slipped past your google search. Go work on your Delorean you cracked out Christopher lloyd look a like
Saying the front diff only takes 35% of power has absolutely nothing to do with sludge deposits and how frequently it needs to be serviced, i dont care what a service manual says, How many people on here are still running stock setups, adding 75+ more horsepower takes it toll on everything the service manual means nothing at that point. We have had 7 s10s in our family alone over the years including 2 typhoons, one which had 19,000 original miles and was garage kept, all stock, guess what even that fluid looked like trash when we serviced it then. The proof is in the pudding and thats what the front diff fluid looks like if you dont change it
