Re: datamaster help
I checked the chip program and it was made for the PLX, so it seems you have something else going on. Either a wiring problem, or a problem with the analog output on the PLX.
Make sure you have the analog output (not the narrowband output) of the PLX connected to F14 at the ECM.
If that's good, then I would check the voltage of the analog output of the PLX, with it powered up and the O2 sensor unplugged. It should be around 2.3-2.4 volts .
