Custom 1" Skulte Adapter Problems
Trevor
Here's an e-mail I shot to those guys detailing my problems in case you guys are thinking about going with a combo with the custom 1" adapters:
Hey...I've been having problems with the 1" adapters I recieved for my Typhoon. When I got them out of the box I noticed that the studs seemed to be excessively long. I put them on the truck with no problem but when I tightened down my brand new $70 McGard splinedrive closed end lugnuts the stud was so long it punched thru the end of the lug and split the lug in half. So much for that. The wheels I have require "tuner" style lugs since there's no way you can fit a 3/4" socket in there so you can't use off the shelf 3/4" open end lugs . I went on a (long) search for some open lugs like this:
http://www.jegs.com/photos/359EKTuner.jpg
$30 later still no dice...the lug bottomed out before it seated against the wheel.
I don't know what I'm going to do now. Granted I could take a dremel and hack off the last few threads on all the studs but I'm sure the lugnuts would be fun to get started on the hacked threads. For the cash I laid down I shouldn't have to do that.
The thing is I payed extra for custom 1" spacers. It seems that you may have mistakenly used the same studs that you would use on the off-the-shelf 1.25" spacers. If it wasn't a mistake you guys should get the correct studs so that this doesn't happen to the next guy or just quit offering the 1" spacers all-together.
Thanks for your time...
Trevor James
Crazy J
Re: Custom 1" Skulte Adapter Problems
just put a nut on the stud then cut the stud off, when you remove the nut it'll clean up any burs or roughness left from the cutoff.
Trevor
After cutting down the studs (good tip there Crazy J) the Enkei CP1's are on now. They look pretty damn good but the truck needs to be dropped & cleaned up before I post pics.
