Re: converter help
Brake stall and flash stall are two different things. If it's a 2400 stall it should flash to 2400 before the truck moves. Easiest way to tell is role down the road and stomp it, where it flashes and then moves is typically where it is set to stall. You cannot usually brake stall to the flash speed either. It's usually easiest to command a gear and try it too.
Loose and tight is also another term, but it is usually indicative of the methods used by a manufacturer to establish a stall. One 3000 stall from one company can feel totally different than a 3000 stall from another company. I've driven cars with 3000 stalls that you couldn't even tell were in there until stomped (tight) and others that felt like you needed a lot of throttle before it moved (loose). A reman converter with stall modifications typically feels loose compared to say an ATI/Yank etc. that build all their converters from scratch.
