Cam Kit?
SYKLONE866
I am going to put in a new cam, rollers and timing chain set...what is the best cam to go with, Have the JRW forged pistons and eagle rods balanced, going to port and poilsh my heads and intake, have the crank done so I need to know what cam kit to get .......any suggestions will be appreciated....
thanks in advance...
ghettosled
SYTY SUPERSTORE
it all depends on what chip or computer you are using. If you want to stay with the stock chip, or stock injectors it is best to stick with a cam as close to stock specs as possible.
If you upgrade to the 50# injectors, we offer a chip for heads/cam. OUr recommendation for this chip is the Comp Cam PN 09-412-8. Many people on this list have used it, and if you use the search function you could probably come up with a couple posts.
We have these cams, lifters, springs, retainers in stock. Email or call for pricing.
