cloneman315
ok well hopefully mine dosent break but if it does are u guys just running to the junk yards etc or are u rebuilding yours?are there any upgrade parts u can put in them ?
George Blake said:The main thing "breaking" in them is the viscous clutch component. When it ramps up to full hump(from fluid shear), the silicone expands from heat. There is an air gap(bubble) in the viscous housing. Once the heat and pressure gets so high, the viscous will crack like in the pic that Jeff has of Jeremy's transfercase.
REBUILD INFO FOR BORG WARNER 4472 TRANSFER CASE FOR SYTY
http://www.drivetrain.com/transfercasesparts.html#Borg-Warner 4472
Borg-Warner 4472 & 1372 All-Wheel Drive Transfer Case 1990-1998 Astro & Safari / 1991-1992 Syclone / 1992-1993 Typhoon / 1991-1997 Bravada
PART NUMBER
PER UNIT
DESCRIPTION
TYPE
YEARS
COST
K272000 - Rebuilder Kit - Bearings, Gaskets and Seals $109.29
K272900 - Overhaul Kit - Gaskets, O'Rings and Seals $30.08
201207C - Adapter Gasket $2.30
201055 - Input Seal $9.80
201048 - Front Output Shaft Seal $9.00
201087R - Rear Output Shaft Seal 27 Spline Outputshaft $17.28
201045 - Rear Output Shaft Seal 32 Spline Outputshaft $7.28
8008 - Rear Bushing - Not in Kits 27 Spline Outputshaft $12.42
201448 - Rear Bushing - Not in Kits 32 Spline Outputshaft $24.70
272888T - Drive Chain Syclone/Typhoon/Bravada/ S10 1.75" Wide - 43 Links $149.94
Random pitch, one blue linkback, combination round and square linkbacks 272888V 1
Drive Chain - Astro/Safari 1.75" Wide - 43 Links $141.81
