boostvalve
kwick6
Is anyone else using one of these... www.boostvalve.com
I just bought one. It looks like you block off the line coming
from the compressor housing. And take the line from the back of the intake
to one of the ports, and the other port goes to the actuator.
Then set the WG rod to low boost, and then turn up with the valve.
Just checking to see if this sounds right.
Later,
Scott
Tooky
Serious about performance
I wondered about why they want a manifold boost source as opposed to the compressor. I also wondered last year what would happen if you used manifold boost to power the stock wastegate solenoid (with no boost valve). Seems like it would have a laggier response, I dunno.
kwick6
The boost you make at the compressor isn't going to be what is at the manifold. It depends on your intercooler efficiency, there will be a pressure drop.
Not sure if that is why they do it, but its my guess.
Scott
InvisiBill
How exactly do these things work? I guess I don't understand enough about how all this stuff works together to control the wastegate...
nick041881
My friend and I just installed one on his turbo mr2. Went from 7psi to 15 psi! holds 15 psi perfect. i was impressed...i am gonna use one on my truck.
peace,
nick
InvisiBill
