Re: boost launch in D or OD ???
jbonehead85 said:
I recently read a forum where someone asked how to boost launch. When it was explained the person said to launch in drive not overdrive. Does it make a difference, and if so then how? Do you have to shift into OD in the 1/4 mile????
Another difference I didn't see mentioned yet, is the fact that most SyTys I've seen, from the factory if the trans is left in OD it will engage 4th gear way too early, around 80MPH and 3800 RPM (just off the top of my head, might be a little off). I suspect it has something to do with the uncommon arrangement the tranny has to allow a 3-4 WOT shift (something the majority of 700R4s can't do).
The tranny shifting into 4th gear too early will keep the engine from operating at Peak HP (RPM) going through the top end of the quarter mile.
Typically the shift to OD in the 1/4 Mi happens around 95-100 MPH depending how high you want to shift your truck. I would recommend 4500-4600 RPM. I would say most stock-motor trucks don't absolutely "NEED" 4th gear until they get into the mid-low 12s. At that point you begin losing a few tenths/MPH if you're stuck in 3rd gear.
