im having some problems getting solid boost control on my PT52. it looks like i get about 2 to 2.5 lbs of fluctuation with the PTE set up. i followed the instructions to get 15 lbs, then i adjusted it in a little farther after several runs to achieve 16 lbs. i ended up settling for a max of 16.8 and a min of 14.
if you look here
http://e-rue.home.mindspring.com/pt52_5.uni
you can see what im talking about.
dont laugh at my slow spoolup, i still have the stock converter, and that small piece of 2.5in exhaust where the cat meets the ATR exhaust.
this,
http://e-rue.home.mindspring.com/pt52.uni
is the first run, where we had the wastgate too tight. i hit over 18lbs without it bleeding off boost, so i let off the gas, and went back to the garage to readjust.
here,
http://e-rue.home.mindspring.com/pt52_2.uni
http://e-rue.home.mindspring.com/pt52_3.uni
http://e-rue.home.mindspring.com/pt52_4.uni
are several more runs where i tried to dial in the boost unsucessfully.
e
_________________
syclone #2449
mccoy motor
KB air to air
ATR headers and exhaust
PT52 with downpipe and cat
BG 50lb "heads and cam chip"
<font size=-1>[ This Message was edited by: E-RUE on 2002-04-01 19:32 ]</font>
if you look here
this,
here,
e
_________________
syclone #2449
mccoy motor
KB air to air
