warmpancakes said:the BS3 transcontroller is basically a T-com built in
then its "simulated" seq not true seq10secTy said:With better TCC control.
Also some people might not know this but the Bigstuff also has Knock retard now and it does not need a Cam signal for Sequential operation only a crank signal.
Nolan
warmpancakes said:then its "simulated" seq not true seq
10secTy said:Yep with out the cam is simulated. I tried both on a 421" small block with 160lbs injectors and you could not tell the diff.
Nolan
