spooldup
Super Member
Hi guys. This weekend i moved my battery into the rear of the Ty. I searched through the posts here looking for some way of getting the ground wire outside to the frame WITHOUT drilling any holes but was unsuccessful. So this is what i did. I ran a piece of 1/0 from the rear of the Ty down to where the driver's side seatbelt main bolt is. It's a big torx screw. Then underneath the Ty where the seatbelt bolt goes through the body of the Ty i attached another piece of 1/0 and then bolted it to the frame. It seems to be working well for me. I don't like putting holes in the Ty so this is what i came up with. If you guys don't like the arcticle delete it. I just figured i would throuw it out there. Here's some pics.
This is the general view of where the ground goes inside.
This is the closeup. What's cool about this is that you can put the cover back on so you can't see anything.
This is the view fron underneath where the seatbelt bolt goes through. I put another nut on to hold my new cable.
This is the view where the ground wire terminates. It comes from the seatbelt bolt. It's about 1ft away from the seatbelt bolt. I sanded it down with a dremel and then threw it on.
Hope this helps someone. O my positive wire was ran under my carpet and then out side in the front. Nothing special there.
