AFPR install?
Mephisto
These trucks are cursed
getting prepped to put this in. but im thinkin i need a datamaster and a fuel pressure gauge right? are there any tips on the install i should know? TIA
Daron
I bought a fuel pressure test gauge from Auto-Zone that screws onto the schrader valve. It has a flexable hose, and pressure release valve built in, cost like 30 bucks.
Remove the Turbo to IC hose, loosen the clamp on the output of the IC, then remove the IC. I use a swivel, 9/16ths socket and a long extention.
To get the original off, a short 5/8ths open end on the bottom of the regulator and an allen wrench for the two screws that hold it to the rail.
Don't forget to put the o-ring on the new regulator, and KB regulators need the spacer put on before the o-ring.
