AC not working .. need help.
junkydogg
The AC on my truck is not working, the compressor is not comming on. fuse under the dash is good, is there a relay on the firewall or something i am overlooking?
nomoty
Still Boosted
Someone correct me if I am wrong but while truck running pull plug of silver cylinder next to coolant resivoir and connect the 2 sides with paper clip. If compressor clicks on try charging your refrigerant. May want to do a leak check first before you have r-12 put in since it's so exspensive. Like I said someone correct me if I am wrong.
you are correct...
if there isn't enough pressure in lines, pump won't turn on.
like stated, jumper the connector located on silver tube (Dryer is real name)...
that is pressure switch...
junkydogg
tried jumping the wires and nothing happend. in the manual it says there are 2 fuses for the AC. wheres the other one besides the one under the dash? any other ideas?
syclonekid43
have the system checked for leaks you can put some dye in with it when you charge it then go over it with a black lite to find leaks if you have any and you can save some money by changing over to r134. all it has in the kit is diffrent fitting i done about 40 45 cars last year with the change over kit and never came across a problem eith it
syclonekid43
send me an e-mail tommorow i have the typhoon syclone manual down at my shop or give me (203)755-2712 during the day ask for chester if you ask for roberto i wound come to the phone ill yhink its a bill collector callin
