9/11 t/c
Turbo6
10.20@131.8
Re: 9/11 t/c
Quickest et with stock motor without nitrous with one 11.10
Fastest MPH stock motor without nitrous with one 119
Quickest ET with stock motor 10.93 with one
Fastest MPH stock motor with one 121.99
Quickest et with factory ecu or 700r4 with one 10.20
Fastest mph with factory ecu or 700r4 with one 132.5
Best 60' with stock motor with one 1.47
Best 60 ever with one or 700r4 1.41
but what do I know.. could think of alot more but its late I love my 3500 stall 9/11...wanna see one run 9's? still have a little cam, turbo and IC stay tuned
NOJIMMY
Re: 9/11 t/c
No flames, but you do realize that selection of a TC is more than "brand selection"...
-Lockup or nonLockup
-Stall Speed/Rpm selection
-Motor buildup (cam, torque, hp, rpm output)
-Correct Installation (lubeguard, pre-filling, proper seating)
-Correct Transmission operation/adjustment
-Proper cable and linkage adjustment
Lastly, my advice, ride in a Sy/Ty with an aftermarket TC. Many of the
listmembers dont know "proper operation" and driving
characteristics of a custom TC when driven on the street.
For example, are you a "shifter", 1-2-3-OD......or D-to-OD person....or strickly OD.
Not saying you dont know, or haven`t thought of these items above.
Just saying, some people like Levi`s, other`s Wrangler, still other designer jeans.
LIke boxer-briefs, a lot depends on what you like, want, and intended use (ie maybe
your a free-spirited-no-underwear kinda guy...and are strictly business.)
syco 2
Re: 9/11 t/c
im all over the place with the shifting if im feeling sporty i shift the truck but mostly around town its d then above 45 its od. im not tryin to burn the 9/11 i herd it wasnt that good but hell if u can do that with it turbo6 then sh** it must be good. what about for the street?
Turbo6
10.20@131.8
Re: 9/11 t/c
Works great on the street. Drives around like normal....hell I drive it to work a couple days/week.
sytyguy
Moderated User
Re: 9/11 t/c
I daily drive my 3000 stall unit and it has never given me a problem in the last 6 years (mine is one of the EARLY ones from around 1998/99). Matches my combo beautifully and cruises like a tame converter.
I have always had good luck with 9/11s (installed 5 so far in different cars/trucks).
Hood
jwaller
Evil Genius/SyTy Guru
Re: 9/11 t/c
Maxtor said:
What he said :tup: .
what he said. :) I've installed and or sold prob 2 dozen of them(over the last 8 yrs) and the only problems I've heard about are usually due to prexisting problems with the tranny/driveline that installing any higher stall conv would have done.
let it aso be said that with any conv installation and even without it, you should have a very large trans cooler and grind the last large land off of the PR valve so that you get full time cooling from that large cooler and install at least a 0.500 boost valve to restore the pree drop from grinding the land off.
KETCH-UP
Re: 9/11 t/c
Agree with above comments. I have a 2600 9/11 mostly stock and it is coupling up torque even with boost. It helped my 0-60 times more than any other mod. I get a very hard lock-up sorta like there is 5th gear. That took some getting used to. It couples up so good it makes my turbo seem too small !
syco 2
Re: 9/11 t/c
thanks for all the info. for a pretty much stock truck would to much stall hurt performance? like 3000-3200.
jwaller
Re: 9/11 t/c
I dont think a stall conv will do much for a stock truck. I would not go over 2800 is I did. if you go that hi your killing off a lot of usable rpm for the stock eng that dies out about 4800.
syco 2
Re: 9/11 t/c
thanks. also does it matter what company does the 9/11 come from? i could buy a neww 2800 stall its by kenne bell???
jwaller
Re: 9/11 t/c
yes the company you get it from makes all the differeance. the true 9/11 only comes from TCS in the USA. all other 9/11's are just copies and do not compare the the original.
also do not waste your money on a multidisc converter of any type. they rattle and confuse the knock sensor into thinking your eng is coming apart, they also sound terrible at an idle as the multidisc's just rattle around inside the conv.
