700rv valve
Nasariobv
Yessss, i had the valve body on my tranny replaced, and now sy106 is shifting just fine, the mechanic notice no internal wear, just very dirty valve and valve socket........
Nasariobv
the valve
the valve
it was the lower valve , the one that sits right above the valve body assembly. $20 part , but $300 labor......damn
jwaller
Evil Genius/SyTy Guru
Re: the valve
Re: the valve
ok. glad to hear it's working for you. do you still have the original valve body?
Nasariobv
damn it happend again
the damn valve is sticking again!!!!!! :evil: :evil: :evil:
does anybody y this happen so much its the third time in a year..........ive changed the fuild every six months.....
B
Blake
Guest
The description you are giving of the valve is....well....not really helping us.
Maybe you are talking about the governor assembly?
There are two lineups that go UP into the pump and there are many that go horizontal into the valvebody. There are two lineups that go into the auxillary valve body. Not real sure which ones you are talking about.
The TV valve way down in the valvebody is notorious for sticking (there are a few fixes for it) but don't know if that is the one you are talking about.
You are either overheating your transmission(valves will stick every time it gets overheated), or you've got a bunch of junk in your case, cooler, or TC and your breaking it loose at fluid changes and it's getting stuck in the valves. It's not like your engine. ANY junk in the tranny and a valve WILL get stuck.
$300 labor.....ouch. Most of the guys around here only charge $700 labor to rebuild the whole tranny(delivered on the bench).....why don't you take it somewhere else?
There are no valves in the case.
Before you take it to another shop, get some Lubegard, warm the tranny up, pour in the lubegard while its running and take the tranny out and cycle it through the problem area of driveability and see if it will break it loose.
George
Nasariobv
thanks blake
thanks blake
yes itis the tv valve that sticks....i keep changing the fluid and trying to clear it, it helps but after a few 100 miles it starts sticking again........what do u recommend.....lubeguard???......or something else...
jwaller
what did they replace it with? try libeguard it's some good stuff but who and where did you get the tv valve from?
Nasariobv
the local shop
the local shop
this shop by my job said they knew how to fix it, they tap into it and put a new valve?????does that help.....but when i called him they quoted me 200 bucks to retap it and loosen it up......where can i find some lubeguard????i tried the local pepboys and autozone but no luck...
jwaller
Re: the local shop
Re: the local shop
any good trans shop should have it in stock
kwick6
Re: the local shop
Re: the local shop
try Napa...only place that sells it around here.
