700R4 removal from Typhoon...Help Needed!!
paul30
paul30
Any advice/tips on the R&R would be very appreciated. I have no experience with this but am contemplating doing it. The more details/diagrams etc. the more it will help me. Thanks...Paul
NJ93TY
Re: 700R4 removal from Typhoon...Help Needed!!
Paul, why are you removing the transmission?? First I would suggest finding a friend who has some experience in the automotive world, second, I would not do it on the ground, it will suck.
SY2932
Administrator
This is the "how to" write up that I used when I did my first pull six years ago.
These two posts here and here will help you out too. I'm going to edit that last link so that it has the pics that are missing...
Pulling a transmission isn't for the faint hearted. Difficult bolts to contend with in a very confined space. Reinstall it incorrectly and you'll be lucky to get down your driveway and back. I can usually do a pull by myself without a lift, in two hours start to finish. If you aren't comfortable doing it, you are better off biting the bullet and paying someone else.
Norm
Having done mine, I would think about getting a tranny jack, that way you can tilt the tranny up/down. Having a helper is also a big plus. Drain the fluid, unbolt the convertor, disconnect the cable/wires. Buy me a plane ticket and I'll come help you take it out.
Jimmy
Banned
The link Mike posted is the shit. Not bad at all to pull,but do not remove the transfer case brace,it will come out still attached.
TYTILIDIE
METH HEAD
http://www.syty.net/forums/showthread.php?t=56730 You can read this too. I find best thing is to do it in a certain order, believe it or not, the x member is one of the frist things to come off for me because it allows you much easier access to a few other things. Not sure what all Mikes how to says but one thing someone on here mentioned once was the use of motorcycle straps. I dont sue them for removal but for install. When doing this alone, it is nice for piece of mind to use this method.
