7.5 10bolt max abuse ?
Windedv6
Ty n 10s
Re: 7.5 10bolt max abuse ?
how much abuse will this little sucker hold if built correct with girdle,new eaton unit and moser axles? how fast have people gone with the 7.5 on these trucks with a v6?
10.61 @ 132 mph in a 4,200 lb Typhoon with gridle cover,Eaton posi, and Moser axles in mine.
John
Windedv6
Ty n 10s
oh ok that has me feeling a bit better lol. what diff do you have on the 9sec truck?
The TT TY has a Chris Alston Chromoly Fab 9 housing with a Moser Aluminum bolt through center section, 35 spline gun drilled Moser axles with star cut hubs and a Detroit Locker diff. I am not to worried about having a problem. Of course we can always break anything as nothing is ever bulletproof. I posted some pics on the setup...;)
Windedv6
Ty n 10s
So how much can the 7.5 take, Depends on how hard you push it. fwiw imo dont waste any money on it. fwiw broke while in the 10's i think. here ya go. ouch
http://www.youtube.com/watch?v=L3WQGiWpeBc
I believe you had a stock rearend setup and it looks as if you don't have c-clip eliminators or you would not have had your axles come out. The moser axles are stronger than stock and anyone changing out their axles and diff should be putting in c-clip eliminators so the axles can break without coming out.
John
bezerk
what part number to the c-clip eliminators? cladding is more expensive than those, prolly.
ed hess
race or get outta the way
John
John,
All true!
however the 7.5 wont take it. When the housing was removed we saw the housing was bent from all the abuse. As original owner, i know it wassnt bent when i bought the truck so dont waste your time on a 7.5.
bezerk
John,
All true!
but you don't know if the damage was done before the c-clip went out?
ed hess
dont say i didnt warn you ... but i broke mine with a stock block setup.
autoaddictions
I made around 200 passes ,300 + burnouts in the 10s. It finally shit the bed end of last season. Bone stocker no girdle.
