wildphil;n1862056 said:
Is the pattern on your Bravada 5x120.65? If the new Camaro pattern is 5x120, I believe that is the same as BMW. And I think that I have seen threads on this site about members using BMW wheels on our SyTy's and they fit with no mods. Are the lug nuts bigger diameter on newer Camaro than on your Bravada? If so could you not just purchase lug nuts that are the correct diameter as on your Bravada to use with the wheels? Please do a little searching for info to see if it is correct or not. I may be way off on my thinking. Also, verify how much length you need the lugs to be. The lugs on my Ty were to short when I upgraded wheels. NAPA sells longer stock diameter lugs for our trucks.
Edit: Do Camaro's have offset wheels? Does your Bravada? These are other factors, but you may already be aware of these.
wildphil, Thank you for your reply. I have been doing research but much like Bono, I still haven't found what I'm looking for but here is what I have and have researched so far.
I have a pair of Moog 513061 Hubs with the standard GM 5x4.75" (5x120.65) bolt pattern and M12x1.5 studs. My Rotors are PowerStop Evolution AR82113XPR 14" rotors also with a 5x4.75 bolt pattern from a 2013 Z06 Corvette. My wheels are 2010-15 Camaro 20x8JxIS35 (Front) and 20x9JxIS40 (Rear) both use M14x1.4 studs. (Yes, I know the're filthy. I just bought all 4 for $350 and haven't had a chance to clean them up yet.) The 5x120 and 5x120.65 are close enough on the pattern that it is not a real issue. I have been reading through the Sport Machines 14" Z06 Rotors + 4 Piston CTS-V Brembo Calipers thread and see that many wheels seem to fit, but the problem I seem to be having is the hub center bore of my wheels is about 1/8" smaller diameter then the hub assemblies. According to Moog's website, the 513124 hubs mentioned for the 2000+ Blazer/Jimmy list the same 70.1mm (2.759") Wheel Pilot Diameter as my 513061 hubs. The Camaro hubs have a 66.9mm (2.633") Wheel Pilot Diameter. I was just hoping that someone had looked and found a bolt on hub that has 5x120/120.65 w/ M14x1.5 studs and 27 splines (not 30 like the Camaro), I may just need to have the wheels opened up to fit the S/T-Series hubs. That way, If I have a hub failure, I will not have to have a hub turned down again before it can be used. I will try contacting Moog tomorrow and talk with their tech support, but I'm a bit pessimistic on the outcome being favorable. :lol:
Thanks in advance for any help or advise you guys have.
P.S. I tried uploading some pics, but I wouldn't let me post them.
