116 octane
116 octane
I have never heard of 116 octane unleaded gas, so it I'm sure is is leaded race fuel. True, it should help your knock and allow you to change your advance and turn up the boost. Your O2 will probably survive unless you run 116 all the time on the street (if you do, boy would I like to know what you do for a living to be able to run $4 1/2 P/gal gas! Do you need an assistants or any trainees?) It will NOT do your CAT any good at all. Turning the boost up that high on a stock turbo and disconnecting the CAT from what everyone tells me is dangerous for the engine and not the way to go. I just bought a PTE 52 kit with downpipe & 50# injectors to aovid the breakage problem that might occure with disconnecting the CAT and running race fuel with high boost, which is exactly what you are thinking of doing. (OK, to be honest I didn't only buy it to be safe, I bought it to go FAST!) What you're thinking of doing is something everyone has thought at one time or another. If you do please let everyone know how it worked out
