Re: 10 vane pump 700r4 question
The area where the front seal fits into looks all there so it shouldn't leak. Can anybody with some experience with these offer some advice? should I keep it? Thanks
You're right. It won't leak, but the more important consideration is that that bushing stay in place and not walk forward. I don't have any experience. But I'll offer an opinion.
Those notches aren't there on an OEM pump. The front bushing can dislodge, move forward, and terar out the front seal, causing a massive leak. This usually happens fairly soon after an overhaul. So the builder eats the additional R&R, and if it got driven to no-fluid, has to re-do the frictions as well, as they are usually burned up too.
On rebuilds, most builders cut two notches
on the other side and stake the bushing into the notches as an accepted, and common cure for this problem. It looks like someone got confused, or wasn't paying attention, and ground the notches in the wrong side of the bore. The notches are supposed to be on the back side so they hold the bushing from walking forward..
Look down in there. Can you see "stakes" in the bushing? If so great. If not, whoever built the pump didn't perform a widely accepted "this must be done" task on your new pump.
In this pic, the notch at 12:00 appears to line up with the oil drain-back hole. This is another part of the "seal blow-out" fix is to enlarge the passage. It looks like this notch lines up with the hole itself in the body indicating the hole was drilled from the other direction, and the drill bitt was allowed to hit the inner lip and notch it too. Plain ole' butchery. Doesn't happen unless the builder is careless.
Why didn't you just purchase the 10-vane kit and a couple of misc parts and rebuild your existing pump? They're not hard to do. And the parts cost about $15.00 jobber price. Seems like a lot of money for a spray-paint job.
