vibration
93 typhoon
I am geting a vibration wen i reach 65mph i do not have a propshaft waiting for the new one to arrive. So it's not the propshaft. Any one have this problem? I know that there was a thread on this i could not find it. I will appreciate it for the help. Vibration driving me crazy.
jjorgensen52
NHSTE - I'm the only one!
Re: vibration
Have you had your wheels and tires balanced on a high quality balancing machine?
ty166
Re: vibration
OH SH*T....... NOT YOU TOO........lol , i feel your pain..... i spent mega $ chasing my vibration. there is a recent thread on this. search the word vibration and it'll come up. i have repalced entire front end , upper and low control arm bushing and ball joints , all tie rod ends , idler and pitman , all u-joints and driveshafts balanced , sent rims to be straightened and balanced , new tires , prop shaft out , front shocks , front hub and bearing assemblies , converter .... and still there. many people are dealing with this same problem , noone can seem to come up with a remedy.........
93 typhoon
Re: vibration
Here are some of the thing that i have done to the truck. upper and lower control arm bushing, ball joints, idler arm,and new shocks. this is what i iam going to buy nex. pitman,converter,and tie rod ends.
Re: vibration
has anyone with this problem tried finding a known good set of rims/tires from another vehicle that will fit our trucks (even if the offset is different as long as they clear the caliper/rotors it shouldn't matter) and driven your truck to see if the vibration goes away??? :2cents:
ty166
Re: vibration
im getting a set of z06's for mine, if that doesnt fix it it then becomes the wifes daily driver, she never gets on the highway (trust me thats a good thing) .
ty166
Re: vibration
pullin these trans blows , if your changing your converter hoping it will fix the vibration you'll be very upset when you find out all that work and it still vibrates.... been there done that....
93 typhoon
Re: vibration
I have a nother set of rim's put them on and the truck still vibrats.
93 typhoon
Re: vibration
I have the stock converter i need to pull it out any way i want to put a 2800 stall. pullin the trans out dose suck.
ty166
Re: vibration
my next thing is since its winter, the rear end is out and getting switched to ls-1 , deleting rear air ride and going with bilsteins , abs delete (hopefully kits on its way), c-5 fronts if i can come up with some adapter brackets. but for the vibration i'm going to replace both front 1/2 shafts and replace front diff bushings , maybe a gear box and lower steering shaft, i cant see anything else that would cause it......
93 typhoon
Re: vibration
I am going to delet my ABS going to install a Hydro-boost from a mid lat 90s astro van. i was thinking of replaceing both front 1/2 shafts i think i will do that nex week
