canadian
sy in progress
I have read in articles here and there that oiling the bottom of the piston can be benficial in keeping the temperatures down. So then I came across this nifty buildup here:
For What Its worth, the piston shown was CAST by a Japanese company called ART for use by Toyota in the 93-98 Twin Turbo Supra.
They have been known to produce over 800 HP in these 3 liter engines using the stock cast pistons. Notice the bathtub stopper chain traveling through a hollow "tunnel" in the dome. Oil is squirted in one of the holes and exits the other.
The Honda parts on the right are the ones I chose to use in my SVO. The mounting bolt doubles as the oil feed and favors the 2300 block layout better.
The mounting bolt also serves as a two stage flow regulator.
http://hometown.aol.com/fourced/page18.html
With the jetting installed in the block...
http://hometown.aol.com/fourced/page19.html
To me, it looks like as the piston comes down it will meet up with the jet and have the oil squirted in the hole and back out the other side of the piston. I believe that even spraying on the bottom side of the piston can help keep temps down, but I'm no engineer. Another question would be how to get the oil to the get in the first place...
Just an interesting tech thought.
