trans temp gauge hookup...
psmvchaser
I have a mechanical tranny temp gauge that I am going to install.
Where should I put the sensor? Is there any easy spot to put it?
Ken
InvisiBill
I don't even have my gauge installed yet, but I've heard that the pan isn't a good place for the sender. The large volume of ATF in the pan has a lot of mass, so it will take a while to all heat up. If your sender isn't near the hottest part, it will take a long time to see that heat. The fluid leaving the transmission should be the hottest point...
