Tranny probs
N
nosrevi
Guest
when I put truck into park it still moves, when it rolls you hear a slight clunking noise, this is a tell tale of what?
Also the shifter seems to be off slightly the R D 2 1 do not line up like they should, this is an all of the sudden problem.
Truck does not shift like it should and often get a hard downshift when comming to a stop, I have not put the truck on a lift as of yet only thing I have looked at was tranny fluid lv and color both look good.
jwaller
Evil Genius/SyTy Guru
sounds like you need to adjust the linkage. its not actually moving the lever on the trans all the way forward.
