Top engine cleaner question.
G
Guest
Guest
Going to try this next weekend as this weekend is designated to the Walbro fuel pump :grin: My question is: You say to put this in the brake booster hose; do I have to remove my boost gauge line during this? Man I hope this works.
jwaller
Evil Genius/SyTy Guru
yes thats one way to do it....make sure you change the plugs and oil afterwards and maybe the o2 sensor as well
G
Guest
Guest
I have a new o2 sensor now. I think I'm going to put the old one in during the process. That way I dont have to spend the extra $50 on a new one.
_________________
Todd Anderson
http://www.sytycentral.net
NC Syclone 760
<font size=-1>[ This Message was edited by: ncsyclone0760 on 2001-11-22 08:59 ]</font>
smeagol
You could also just take out your 02 and jam an old spark plug in there to seal off the exhaust. Pretty sure some plugs are the same thread as the 02s. Or I could be smoking crack again; if so, you could jam your finger in the 02 sensor bung too.
You'd set codes either way, but that's easy to remedy.
Brian G
G
Guest
Guest
just got the regular 255. Ron told me that for what I was planning preformance wise (not much) that it would be fine.
