bjzq8
New to the forum...new to SyTy's too.
Just got my 1992 Ty last week...75K miles.
Previous owner says that every "consumable" ignition component (plugs, wires, cap, rotor, etc) has been replaced very recently. It has ATR plug wires, and AC plugs. It also has an ATR Pitbull chip. Stock everything else...stock boost, and somewhere in the neighborhood of 15psi of boost on the stock guage (inaccurate, I know...)
Acceleration from a dead-stop is beautiful. But in a 50-mph roll on from relatively low rpm, I get several seconds of audible knock, accompanied by the tach jumping. The tach doesn't always do this, just on occasion. Now, I have a bit of background as a GM tech, and this is what I make of it...the TACH signal is basically just a signal put out whenever the pickup coil gets a spike. So these tach jumpings would make me think that either the ignition module or pickup coil is bad. I suppose you might throw in bad grounds or a loose connection. But it only seems to do this under heavy acceleration, and is always accompanied by knock.
The vehicle runs great every other time. It has an admirable idle for what it is, and goes like stink, like it should. I seem to have a rather long spool-up time from a non-boosted launch, like maybe .5-.75 seconds. Anything I should worry about?
Sorry for the long first post, but I thought I'd throw a bit of everything in here. I've searched the archives and have come up with ignition wires, ignition wires, ignition wires. But I'm reluctant to replace some brand new ones...unless that's really the problem. Everybody else seems to have idle tach bounces...mine is fine at idle. By the way, my background is Fieros, specifically V-8 Fieros (www.v8archie.com). Which are bears to work on, as you can imagine. So I'm in vehicular valhalla with my Typhoon! Might be difficult, but certainly not a hothead Fiero! Thanks for all of the advice!
Bill Jenkins
1992 Typhoon #1752
Bill Jenkins
1992 Typhoon #1752
