No reverse
jeepruby04
I just had the tranny totally rebuilt with what was said to be upgraded parts not more than 200 miles ago, and now when i put it in reverse, i can feel it engage but it will not move the truck. All forward gears work properly and shift firm. The fluid is new synthetic, full, has good color, and dosen't smell burnt. Is this a valve body issue?
Captain Morgan
Moderated User
Re: No reverse
could be something stuck in the valvebody, I know I had that issue with OD once on a new build, but Im no tranny expert. I also wouldnt have went with synthetic fluid, a quick search on here will yield why.
1madgumby
Re: No reverse
If you put syn. trans. fulid in & it burns up the trans up faster, because it slips the clutch more because of the syn. fluid prop.. I use only cheap trans fluid NON syn..
