Flyin Ryan
hated cuz he drives fords
Just wondering what is the normal Idle speed for our trucks?
cause mine idles at 500 to 600 rpms when at a stop in gear.
Maverick87 said:what chip are you running ? Also did you get the numbers from dm or just looking at the tach?
Maverick87 said:idle should be in the 650-750 range. sounds like the boost gremlens are after your motor. need to be real carefull till you get that CHRISTmas present.
SyTyArchives said:20 psi?
other places to look for the high boost cause:
do you have a full exhaust?
bad vac lines on turbo/wg?
bad boost selenoid?
bad wg actuator?
mis-adjusted wg rod?
